How to show unit number & Block postal code in overall project?
Hi all, I would like to ask some question.Now my project need to show unit number & block number.For example, this project has 10 blocks, every block include a lot of units include.Let say, 1st storey has 4 unit, I want to show 1-01,1-02,1-03,1-04 like that. This unit need to calculate floor area also.So I should use zone tools to create this one.Is it correct way?
Hello yanshin27,
You are able to create two properties
A - One about the 10 blocs (with 2 caracters "XX")
B - One other about 100 unities (with 3 caracters "XXX")
And finaly you have to concat these properties with an expression like :
CONCAT (property A,”-”, property B)
You are able to use this result into your zone stamp to show it on a plan
I invite you to create a schedule to check and control these informations
Note : you are able to do it since Archicad 20
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Christophe wrote:
Hello yanshin27,
Sorry, can you explain again? I am not understood.But I try to show unit number like that.But I don't have I idea about block number.Thanks
All you need :
- about expression is here : https://helpcenter.graphisoft.com/user-guide/84980/
- an example about input your own information into zone stamp : https://helpcenter.graphisoft.com/user-guide/119610/
Christophe - FRANCE
