Wlad222
How to stretch multiple grid elements at once?
I need to adjust the lengths of multiple grid lines simultaneously.
Typically, I would use the marquee tool for such tasks, but it seems ineffective for grid line adjustments.Given the number of grid lines involved, manually adjusting each one is not feasible. I am seeking a more efficient method or workaround to accomplish this task.
Your guidance on how to adjust the grid lines collectively would be greatly appreciated. Thank you for your assistance and support.
Operating system used: Windows 3001 INT
Setup info provided by author
20 Replies 20
No one is actually appointed as a trouble shooter.
Anyone is welcome to chip in and help out.
The more the merrier!
As a moderator I try to read all posts and moderate if necessary, but then I just can't help myself if it is a problem I can help with. 😊
