How to use 3D view properties in 3D document ?
So I've created a 3D section through a model I've made ( It's a tent type shelter inserted into a bag ) The 3D view is ok ( any tips of how I can separate the tent and bag, colour wise ? ) but as soon as I put it into a 3D document, there are lines everywhere. I think it's partly to do with the tool I used to create the actual model but I can't be sure.
Is there any way to use the actual 3D view, save it as a separate document, unlink it from the model so that I can annotate it and later place it on a layout ?
Thank You
undefined
And here's the 3D view :
undefined
TMA_80
Have you found a solution to your problem ?!
AC12_27 |Win11_64bit|
No, Instead I just made the 3D view fit to window and placed that on a layout to annotate, so I haven't actually used a 3D document
