How to use Expressions in Graphic Overide
I have an Expression with "True/False" Data Type or "Area" Data Type and I want to represent in 3D elements with Graphic Overide which have ex. TRUE statement or <0
I managed to use only Expressions with "Numbers" in GO but Area, True/Fals, String, etc. doesn't seems to work.
Anybody have solutions about that!!!
3 Replies 3
poco2013
Mentor
The data types from the expression must match the data type used in the GO criteria.
I expect there is a mismatch in either criteria.
Without seeing your expression formula and the GO criteria --- we would just be guessing.
Screen shots of both DBX's would quickly point to the problem?
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
Actually, the code or formula is OK in expression.
With label Tool it works perfectly, but when I try to add properties in Graphic Overide it shows only properties with manually input numbers, not expressions with formula or TRUE/FALSE
In Properties:
https://www.dropbox.com/s/j3pcicktmhp6sdh/20180729_020845.jpg?dl=0
In Label Tools:
https://www.dropbox.com/s/d2nob3mopiuts3h/Screenshot_20180729-021049_TeamViewer.jpg?dl=0
In Graphic Overide:
https://www.dropbox.com/s/30p8pmr2xqvpt8g/20180729_020938.jpg?dl=0
poco2013
Mentor
Looks like there are no true/false properties in the property manager configured under the group you outlined (Kushtet).
There is a true/false property under the group Kushtet (1) -- Home Storie which you did not expand in GO. Did you try that one??
Gerry
