ā2023-09-14 05:52 PM
Hi everyone,
We recently encountered a challenge while working on a project: the need to display two types of measurements. After some research, I came across the "Secondary Dimension" Add-on, which works perfectly!
However, there's one issue we're facing. In our office, we use the Portuguese version of Archicad, and unfortunately, the SD add-on is not compatible with non-international versions of the program. I even attempted to replicate the international workspace to see if the add-on would function in the Portuguese version, but, unfortunately, it didn't work.
So, I've come here to ask if any of you have encountered a workaround or have any suggestions on how to make the add-on function in versions other than the international one.
Thank you in advance for your help!
ā2023-09-15 03:54 AM
Although technically that is an add-on, it is one that come standard with Archicad as far as i know.
It is not something that you have to install yourself.
So you should find it is installed with the Portuguese version (and I assume all other language versions) already and I would assume it is set to work with each language version of Archicad.
I can't say for sure as I only have the AUS and INT versions which are both English language.
I have never had to install that add-on separately.
ā2023-09-15 03:47 PM
Unfortunately, it didn't come pre-installed with the Portuguese version, so we've had to use the INT version just for it... š
