Read more
SOLVED!
Floor Plan Display: Hidden Part of Stair Tread
Paul Roper
I'm trying to display the hidden part of the Stair Tread as per the attached images.
I have tried a number of combinations of options in the Stair Selection Settings and also the Model View Options, with no success.
I'm quite sure I've seen this line displayed in my own projects before (and have battled to hide it). There is an example at the Archicad help center that shows the line I am talking about (also refer attached image).
Does anyone have any guidance to offer?
Thanks
AC23–26 3001 NZE | i511400F | 32GB | GTX1650
1 ACCEPTED SOLUTION
Solution
Hi Paul,
IIUC you may need to adjust Tread noising option via MVO as illustrated in this video:
https://youtu.be/ADyM3bZyZpI
AC 27 INT 5030/WIN 11
6 REPLIES 6
mija
Try grid fill to none in MVO settings
Archicad 26, build 3001
Montenegro
Thank you for your thoughts.
This is one of the options I have tried, to no avail. Does it work for you? Perhaps it is a clue as to why mine isn't working...
Josh Verran
Hi Paul
Is this perhaps what you are after?
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
Thank you for your thoughts. What you've shown is not quite what I'm after; the attached image shows the result I'm hoping to see (I've used the Non-Slip Accessory from the Tread Accessories and tweaked the settings so that it lines up with the start of each riser):
Solution
Hi Paul,
This is the solution, thank you.
Part of my problem is that I was using the Built-In Stair Grid, which does not have the options for Tread Nosing line types. Thanks to your helpful video I could see that I needed to be using Stair Grid 25 (I am using AC25 for this project):
