2008-10-22 07:31 AM - last edited on 2023-05-30 03:18 PM by Rubia Torres
2008-10-22 07:32 AM
2008-10-22 08:07 AM
2008-10-22 08:37 AM
2008-10-22 09:30 AM
GeNOS wrote:Yes this will remove that node but the dimension line will heal itself.
this part.. select it and delete and it will remove that point in the dim line
2008-10-23 02:25 AM
2008-10-29 11:49 PM
2008-11-02 04:32 PM
2008-11-02 10:09 PM
Djordje wrote:To dynamically change the witness line, select the witness line at the intersection with the dimension line, then in the dimension tool click to set the end of the witness line. To change the witness lines of a section of the dimension string, repeat the process by first selecting the middle node. To change the witness lines of the entire dimension string, repeat the process by selecting the the edge of the dimension line using the mercedes cursor.
What did I forget?
