Roopa A
In section, wall and slab line is not showing
I am using AC 24.
In section, the wall, slab, roof line is not showing in section.
If it is in auto update mode, it is coming like this.
I have attached the image.
Thank you
Roopa A S
15 Replies 15
In the section settings, check to see if the 'Uniform pen for cut elements' is turned on and the cut line pen is set to white maybe?
Roopa A
I turned it on.
But still it is coming same.
Roopa A S
Looking closer at the image it seems as if the lines are there, but instead of being a solid line, they are dotted lines?
Are other sections like this too?
Is the floor plan like this?
You don't seem to have any Graphic Override active - but do you have a Renovation Filter active?
Roopa A
No horizontal section is correct, but all the vertical sections are like this only in this file.
No floor plan is correct only.
Graphic override - no override.
No renovation filter is not activated.
Roopa A S
By "horizontal" and "vertical" sections, you mean in plan, a section drawn horizontally is OK but a section drawn vertically is not?
If so what happens when you rotate a horizontal one to be vertical or a vertical one to be horizontal?
Roopa A
Yes horizontal section drawn in plan is coming correct, but when I rotate it to vertical it is not coming.
When I take the new section line also, it is not coming properly the lines and all in section. I tried all the section settings, but it is of no use.
Roopa A S
OK, I am baffled then and have no idea of the cause.
I have only one more question.
Is it just this file or all files it is happening to?
Roopa A
Only for this file.
Other file it is correct.
I don't know why it is coming like this.
Roopa A S
I have not seen this before.
All I can suggest is there is something wrong with the file.
You could try to repair it.
Save what you have done - if it is important.
Then close the file but leave Archicad running.
Now open the file from the FILE menu > Open > Open (browse for the file).
There will be an option to "Open & Repair Selected File".
If that does not work then I have no idea what is happening.
