Inconsistent hatching for walls intersection in plan.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-04-26 11:03 PM
Attached are two screenshots showing walls with same reference lines but with inconsistent hatching.
How to address this?
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-28 02:23 AM
Just throwing this out there as no one else has mentioned it.
Check the junction order of the walls - they should all be the same.
But that is probably not it.
I would suspect as others have mentioned, there may be something else in a hidden layer that is interfering with the walls.
Select just those walls and drag a copy away from the model.
If they suddenly trim OK then that is it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-26 11:53 PM
Start by looking at your Building Material Intersection Priority
I'm not sure if you are also flagging up the fill pattern, but you can edit the Fill Orientation for a Building Material
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-27 03:10 PM
The issue is how the fill intersect. Attached is a screenshot showing a continuous fill on the right corner but a wrong intersection on the left corner,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-27 04:50 PM
If you are sure this isn't a Material Intersection issue e.g. all materials have different priorities, then have you checked the walls are correctly filleted to a single point even a tiny offset/overrun could create such a problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-27 04:53 PM
I am using the same wall and have filleted them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-27 05:08 PM
AC26 is on build 5002. Are you up to date?
Are all walls on the same layer?
Is the Layer intersection for the walls set to anything other than 1?
Have you checked the renovation status of the walls are all the same?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-27 07:14 PM
AC26 is on build 5002. Are you up to date? Yes
Are all walls on the same layer? Yes
Is the Layer intersection for the walls set to anything other than 1? The layer is set to 1.
Have you checked the renovation status of the walls are all the same? All are New Walls.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-04-27 11:14 PM
Hi Gisele,
in the first picture you have another line missing on the left side, that is there on the right side. Are those 3 other walls, like trims? Are they on a different layer? It seems like your walls are intersecting with some other elements, too.
Dell Inspiron 27 7710 AIO@ 3.20GHz, 32 GB
Windows 11 Home, NVIDIA GeForce MX550 P2000
Florida
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-05-02 07:19 PM
"Dragging a copy away from the model" showed that the problem was dure to overlapping walls.
Thank you!
