st
Incorrect Text Scaling in Imported DWG Files After Reopening Archicad Projects
I usually import DWG drawings (site plans) into my Archicad projects to use them as background references for my buildings.
However, every time I reopen the project, the imported DWG looks wrong — especially the text, which appears at an incorrect scale. I always have to manually update the drawing to make it display correctly again.
Am I doing something wrong?
Can I prevent this from happening?
Thank you in advance
[AC27 6020 INT FULL • HP Z1 STATION 12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz | 16,0 GB ram • Windows 11 Pro]
Setup info provided by author
st
Am I the only one having  this issue???
PLEASE HELP...!!!
