Insulation Line Thickness
The 2D insulation line thickness graphically measures about 4. Is there any way to change its thickness to depict other insulation thickness ( 6" 19", etc)
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
1 REPLY 1
The insulation line type is a 'symbol' line.
You would have to duplicate it and then edit it.
You can copy the pattern, paste it in your plan, resize, then copy it back into the new duplicate line type.
You can use a simple wall that uses a building material that has an insulation fill (fit to skin).
Then you can place a wall of any thickness and the insulation will fit.
