Interactive Schedule Format issues
I've noticed that in using the I.S. the header text will get changed (to Arial, in my case) if it is sent to a List Window rather than placed on the drawing. (Where it shows correctly.) I'm assuming this is a bug rather than having missed something?
There is also a category for "Headline" text, but I can't figure out what type of text this applies to or how to use it. I'd love to be able to make the title of the schedule larger, but don't know how to do this.
Richard
AC26 (since AC6.0), Win10
4 Replies 4
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Dear Richard,
You are right, it is a bug in the localized USA version. (Works fine in International)
About headline: In the schedule settings/fields tab there is a checkbox 'use first parameter as subtitle.' If you check this, the first parameter will become a subtitle (e.g. 'layers') and listed element will be organized under headlines (e.g. 'exterior walls' 'interior walls' etc.)
Please take a look at:
http://www.graphisoft.com/support/archicad/archiguide/equipscheduleswith8IS.html
You can insert new headers by selecting (shift-click) two or more columns and insert header above. Unfortunately, currently you cannot enter multiline text in a header box. However, you can make a header larger by increasing the general column width.
Gergely Kmethy
VP, Customer Success, Graphisoft
I think I was not clear. I meant "larger" as in larger font size, rather than wider. I would like to have the overall schedule label "Window Schedule" be a bigger point size than the headers for the individual columns.
Richard
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Sorry for misunderstanding. Well, the only option you currently have to make the overall title look different than other headers is to make it bold or italic.
Gergely Kmethy
vfrontiers
Yes! I am putting in my WISH for individual attributes for the HEAD text... It would be nice if it could also have individual CONTROL over the borders as well. I'd like the TITLE to be about 2x the text size, bold and just sitting on top of the schedule.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
