cocoloco
Interior Elevation ID for short orientation showing DRG ID instead
As we are working in new archicad 28 file, I have an issue with adding interior elevations and its id.
I have created test zone and set parameters that the interior elevations show name of zone in the middle and show Short Orientation.
The result is that it does not show neither elevation name, but also short elevation. I am ok not showing the name and not be connected with zone, but the short orientation should be respected. I opened other older file we had and it's working ok.
Instead of showing short orientation, it shows "drgID".
Does anyone know how to fix this?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
2 Solutions
David Maudlin
cocoloco:
Look at this part of the dialog box:
 This is for Common IE Marker 1.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
cocoloco
actually it was clicking on "viewpoint id" !
Go to post
4 Replies 4
David Maudlin
cocoloco:
cocoloco
Unfortunately it is not corresponding with the zone, at all so even If I allow layout id, and drawing id, nothing shows. and the short elevations are not still showing either 😞
cocoloco
I did checked the old file, completely same setting. it is difficult for me to find out what the issue is or what exact setting is affecting this 😞
cocoloco
