ā2022-02-04 06:34 AM
After having adjusted my graphic overrides I have noticed I am running into an issue where objects placed in plan and section are overlapping the now bolder line weight of the walls. I was wondering if there was a quick way to have objects display order placed below walls but above slabs without having to manually select each element type and shifting them individually up one display order.
ā
ā2022-02-04 07:17 AM
Nope, you have to adjust the display order manually.
ā2022-02-04 04:53 PM
Disappointing but thank you!
