kylevfa
Is there a way to shift default display order of objects to be placed below walls?
After having adjusted my graphic overrides I have noticed I am running into an issue where objects placed in plan and section are overlapping the now bolder line weight of the walls. I was wondering if there was a quick way to have objects display order placed below walls but above slabs without having to manually select each element type and shifting them individually up one display order.
Nope, you have to adjust the display order manually.
kylevfa
Disappointing but thank you!
