a month ago - last edited a month ago by Barry Kelly
I've been trying to save layer combinations in one project to transfer into another but the xml file will only save as a weird MS file that I can't import into the other project. I can't find any updated information regarding this procedure in AC28, help?
a month ago
Hi there,
I’ve done a lot of work with attributes, but don’t think I’ve actually ever transferred layer combos.
A couple of questions:
- Are you transferring between the same version in AC?
- Do you have all the same layers with identical attribute index numbers in both files? The layer combo export will reference layers by there index numbers only?
- Are you ticking include all associated attributes or not when transferring the attributes to the right hand panel?
- Is the addPars folder being created after you export?
- it looks like your complying the xml file to a different folder, are you copying AddPars too?
Are you able to upload the xml file here to take a look at?
Thanks,
Scott
a month ago
I think the error message is for once pretty clear 😄
But the "AddPars" folder is a red herring. I tried a lot of stuff lately and the Additional Parameters are useful for surfaces only (it just stores the Cinerender settings).
I will write a detailed blog post on that later.
It's really hard to judge by looking at the icons alone, but it looks to me like the OP tried to import a v28 XML in 27, which lands us in the "different Archicad version" territory of the error dialog – the other 2 options can be safely ignored in this case.
We can see that all layers are exported as well, so they should come with the xml. Note: It is possible to just export the layer combos: they will reference the layers by their index only. If you go to a completely different file that is probably not gonna do much good.
a month ago
I don't have Archicad running at the moment.
But from memory, there is no need to export the attribute file (you can though if you want to).
You can simply import from a PLN file.
The file that you are importing in to has to be the same version (or I think it can be a newer version).
I think XML files are more fussy and have to be the same version.
You can then just select the layer combinations you want and overwrite.
I think it will automatically bring in the required layers.
