Patrick M
Layout Book Layer Combos are Broken
Layer combinations will randomly vary from one layout to the next. This is broken. I wish this would work consistently and correctly.
I'll add for those who would claim this is user error, I watched a user create a "Annotation - layout book" layer combination, set it as the layer combo for the layout book, then switch to a different layout and it switched to "A2 - Clerestory Plan" layer combo... this is broken and has been a HUGE problem for quite a while.
12 Replies 12
DGSketcher
Legend
@Patrick M wrote:
If I have one gripe about AC lately, its bugs like this that either make us second guess our documents every time we publish or spend unnecessary hours checking the work already done after publishing.
Nailed it. 👍
If layers are switching between pages, that is an issue.
But not a big issue, as we supposedly only have one layer set in the entire layout book.
Change a layer in any layout page and it should affect all other pages.
So to me it is pointless putting things in different layers.
I am sure you have heard this before.
Put everything in the layout book in the Archicad layer.
That way it can never be turned off accidentally.
Don't annotate or add anything else in the layouts unless it is in the Archicad layer.
If you want to hide something but not delete it, move it to the side of the layout page.
An exception to using only the Archicad layer that I've historically used is for info primarily in the master layouts and title blocks where I have watermarks for "Preliminary - Not for Construction" and similar stamps that I turn on and off via special Layout Book combinations.
