vfrontiers
Transfer Window Door LABEL ONLY
I tried to create a TRANSFER SETTING that would copy a window / door LABEL only and syringe into another window / door...
As LABEL is NOT identified as a unique item to transfer, I could not accomplish this.. I had to choose ALL OTHER SETTING, which brought over essentially all the door / window setting...
any ideas?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Do you mean the window/door marker (in the object settings) ?
No, I don't think element transfer can copy just those marker settings.
Labels are independent (although associated) and can be controlled with element transfer (copy settings / inject settings).
So maybe there is a label you can use that looks like the marker?
Another advantage of a label is they can be used in sections and elevations as well.
vfrontiers
Right... Guess that's an option.
I do already use them in section elevation (OBJECT LABEL; assoc)..
Thanks for the input
Duane
Visual Frontiers
AC3.14 - AC29
