Layout Book
Alison_007
Good! I hope you are okay. I have a question, is it possible to take layouts and masters from another project opened in another instance of Archicad to my current project? for now I can only see.
STUDIO A5 Architect - AC 26 | Computer: |7-12700H | 16GB RAM | Nvidia RTX 3060 | Windows 11 Pro.
2 ACCEPTED SOLUTIONS
Josh Verran
Try File > Interoperability > Merge
There are two options, Layout book or Virtual Model.
I haven't done it myself, but the naming sounds like what you are after.
Perhaps make a copy of your file first just in case it's not successful or has undesired results.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
You can also open the 'Organiser' with that button you were showing.
Then on the left side of the organiser, you can have it look at the other Archicad file (or you can browse for any file - it does not have to be open).
Then drag the layouts and masters from the left to the right side which is your current file.
Just be aware, if you do this, and drawings already placed on those layouts will be linking still to the original file.
So you either have to delete them and place new ones from the views in the current file, or 're-link' them to Internal views in the current file.
I am not sure if the same linking problem occurs with the merge method mentioned by Josh.
It is not something I have actually tried.
Josh Verran
thanks! this worked.
