SOLVED!
Layout info in GDL
vfrontiers
I am trying to find the parameter that represents the drawing WIDTH in GDL...
I know it exists because Graphisoft's titles take advantage of it and it is clearly shown in every drawing in the layout in the SETTINGS dialog..
In addition, I have my own title that uses the GRID of the layout (as determined by the drawing)... But I wen to the current GDL MANUAL and did a search and even that doesn't appear...
AC_GridRect[1]
If someone would be so kind as to point me in the correct direction, I'd appreciate it!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
1 ACCEPTED SOLUTION
Solution
DGSketcher
Legend
@vfrontiers See if any of the following helps. I snipped it from the "Built-in Drawing Tile.gsm".
If the object subtype is Drawing Title then you may find a Parameter AC_DrawingRect containing an array of values you can work with to determine the width. Uncharted territory for me so hope it is pointing you in the right direction...
! Bounding Box Calculations
if AC_titleFitMode = TITLEFITMODE_DRAWING then		! Fit to Drawing Rect
	titlePosX = AC_DrawingRect[1]
	titlePosY = AC_DrawingRect[2]
	titleAlpha = AC_DrawingRect[5]
	xo = AC_DrawingRect[1]:		yo = AC_DrawingRect[2]
	x1 = AC_DrawingRect[3]:		y1 = AC_DrawingRect[4]
	x2 = x1 + cos(titleAlpha - 90):	y2 = y1 + sin(titleAlpha - 90)
endif
1 REPLY 1
Solution
DGSketcher
Legend
endif
