Level Dimension - Text Extension Line
Scott Bulmer
Greetings, is there a way to control the direction of the text extension line for the marker type shown? In the attached image you can see that the text and extension lines are overlapping with other level dimensions causing readability issues. The magenta marks are Level Dimensions, with the blue marks as labels. Thank you, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
0 REPLIES 0
