‎2019-05-21
11:29 AM
- last edited on
‎2023-05-22
11:53 PM
by
Gordana Radonic
‎2019-05-21 05:25 PM
‎2019-05-21 10:19 PM
LaszloNagy wrote:Isn't there a label tool (as in AUT Version) for defining the upper and the lower egdes of an element. We use it mostly for beams, and I suppose it should work with a wall also.
Yes, this is how it works. The Level Dimension can be associated only to Slabs, Roofs, Shells and Meshes using the Gravity feature. It cannot be associated to Walls or Columns so it cannot associatively display their top height.
‎2019-05-22 06:59 AM
‎2019-05-22 09:33 AM
‎2019-05-22 10:57 AM
LaszloNagy wrote:ok i created the custom property and expression and it works with the label tool.
This could also be combined with a custom graphical Label, where one would draw the graphics of a Level Dimension, plus place a Text Block displaying this Property, and save the whole thing as a custom Label. That could look just like a normal Level Dimension, but displaying the height value of Wall Tops.
‎2019-05-22 11:03 AM
papsphilip wrote:Yes you can create your own labels from text/autotext, lines and fills.
Can you elaborate on that last part? i need to draw the elevation graphics myself ? with lines and fills and convert it somehow to a label object?
