Level Dimension Totals
Brett Brown
Hi, Is there any way of totaling the level dimensions text? scheduling?
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
6 REPLIES 6
No, you can't schedule 2D annotation.
I would be interested to know why you would want to add the level dimensions.
Just add a dimension at the top level to get the total height?
Brett Brown
I was afraid of that. We need to get an average level dimension of the level dimensions of the mesh @ 1m centers around the perimeter of the floor slab. This average can give us a higher max height of the building. Hope that makes sense.
Any other suggestions for achieving similar?
I thought it might be an average you are after.
Apart from old fashioned math, the only way to automate it that I can think of would be to have a polygon/polyline object where you can stretch the nodes to the required positions and adjust the heights.
The object would keep track of the node positions (and heights) and then you could have it calculate the average for you.
I am not aware of such an object although there has been some posts here for a polyline based object that could possibly be modified.
Or maybe add columns at the points you want to average (gravitate to mesh).
You could schedule the 'Elevation to Project Zero' to get the heights and of course you can total these.
You would still have to manually divide by the number of columns (points) as schedules can not perform calculations.
Unfortunately you can not schedule the heights of mesh nodes.
Brett Brown
Thanks for that Column Tip, works except I need "Elevation to Sea Level" I need to get my head around converting them to Sea level and seems it's just quicker to paste the elevation text into Numbers or Excel.
Why isn't there an "Elevation to Sea Level"?
I just checked in 25 and it is there.
I haven't opened 24, 23, etc. to see when this came in.
What version are you using?
Your signature says 25 SOLO - not sure if that is different.
Brett Brown
That's good to know, I have 25 but still using 20. All done manually now so I will keep that in mind for when I do it again in the future. cheers
