Level Dimension in RCP
Hi! to everybody.
I wood like to dimension my reflected ceiling plan with the level dimension tool in the plan but the tool gave me the top of my ceiling (slab).
I need it to mesure to the bottom of the ceiling.
Any Help?
5 REPLIES 5
Unfortunately no. The Gravity feature gravitates only to the top of elements.
Thanks for your answer but can I use other markers to do it?
You can use a label instead of a level dim. The trouble with using a label is that the slab has to show in order for the label to show, and the label will show on any story the slab shows on.
Two of the most frustrating half-done features in AC are labels and RCP production, and here we struggle with both.
Here is my slab label from a while ago. In the comment script I credit Geoff Briggs for help, so I'll mention it here too.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Thanks! I will try.
Congratulation for your web.
Thanks again.
Cheers, good luck.
James Murray
