Stress Co_
Level Dimension tool, "to Sea level" default?
Is there a way to set the Level Dimension tool to default to: Autotext- "to Sea Level"?
I'm manually changing it every time.
Marc Corney, Architect
Red Canoe Architecture, P. A.
3 Replies 3
Link
I don't think there is Marc.
If you do want to change them all in one go, just select all level dims, then double click on the text tool.
Link.
Stress Co_
Thanks Link....
Roofs, meshes and slabs..... you'd think they'd make the Level Dimension tool gravitate to walls
Any work-arounds to dim. top of walls in plan view?
Marc,
There are several "top of wall" markers out there.
I have collected one or two that are labels and
I made one that is actually a window.
You are welcome to the one I made and
I will see if I can find links to where you
can find the others.
Peter Devlin
