Level dimension for roof tool to current storey
Morning,
See attached pic.
I'm working on a reflected ceiling plan. I've used the roof tool to create my plasterboard ceiling lining. The ceiling is raked, and I'd like to dimension the pitch levels in plan view with reference to the current storey (marked in red). Any ideas?
Thanks in advanced.
12 REPLIES 12
JaseBee
Ops, didn't mean to swear there, didn't know the filters here were set to the 1920's list of profanities...
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
You are lucky 'sucks' got through.
That used to be censored as well.
kmitotk
If you only need to indicate the heights of the highest and the lowest points of a sloped ceiling, then you can use the label tool with the following expressions (parameters in bold texts)
Highest point A: Top Elevation To Home Story-Thickness/COS(Pitch)
Highest point B: Top Elevation To Home Story-Thickness*COS(Pitch)
Lowest point: Bottom Elevation To Home Story
See attached screenshot.
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 27 JPN USA & INT | Windows 10
