mthd
Line style cannot be edited from AC24 project Migrated to AC26
Hi, I recently migrated a project from AC24 to AC26 and was editing the elevations. I tried to edit my elevation to add extra 2D lines to add a bit more detail to my elevations. I couldn’t change my line from a water line to a contour line from my drop down menu. I restarted AC26 tried again and it still wouldn’t work for me. Does anybody know what might be going wrong here ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
1 Solution
It is a know issue in 26 running on Ventura OS.
https://community.graphisoft.com/t5/Installation-update/macOS-13-Ventura/ta-p/359447
It is supposed to be fixed in update 6000, so try installing that.
That is still a 'preview' update a month after it was released, so your check for updates may not pick it up.
You can find it here ... https://graphisoft.com/resources-and-support/downloads?section=update&localization=AUS&type=FULL&ver...
Make sure you select the correct operating system for you.
Or just scroll the list of lines with the up/down arrow keys.
Go to post
mthd
Thanks Barry, that’s good to know. I tried the Up & Down arrows but it just highlights the navigator on my Mac lol. I will check my updates and thanks for the links.
