Linear Dimensions in the 3D Document Window
Using Archicad v12 I'm not able to use the dimension tool in the 3D window because it is grey-ed out.
The manual says I should be able to however.
Could anyone assist please ?
Rgds
RW
You can't do 2D annotations directly in the live 3D window. You need to make a 3D document, which, while still live 3D, is a fixed viewpoint which allows the 2D to make sense.
The only way to annotate in 3D is with library parts that have a 3D component for the purpose.
Thanks Matthew.
I was confused by the 3D Document definition; didn't realize it wasn't the 3D window
Rgds
RW
