Linear Gradient Fill Construction Method
Chris Grantham
I am have trouble editing the gradient fills in AC 21. It seems the the construction method is greyed out. Has anyone encountered this before? See attached image.
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
There is no need for construction methods with gradient fills.
The editing handle is always there.
Chris Grantham
Of course. Ha! For some reason i didn't think that handle was editable. Thanks Barry.
Mac OS 26
