Lines don't show properly when changing drawing scale -HELP!
I have a project I draw in 1/100 (Archicad 13 mac). Now I need to print my set in 1/500 but my lines (dot line, dash line ...) don't show properly ... they all show out of scale as a single continuos line. I think it is a scale problem maybe or maybe I have to set something on my lines or drawing settings so they scale with the drawing in case I need to print in different scales. How can I solve this? It is really important, i have a deadline tomorrow!.
Gracias!!!
Print/plot or publisher?
When I use publisher and PDF format, the lines behave regardless of final scale.
You are member since 2006, so I wonder if you have new hardware now?
Snap
Srinivas
I think you need to change the line type scale to "Scale with Plan", This option means that if the scale of the drawing is changed, the lines will grow or shrink proportionally.
Hope this helps
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
How are you changing the scale? Are you creating a new view with the reduced scale or are you overriding the scale of a placed drawing through the drawing settings?
The later method would result in the problem you describe.
