Linking content
Since the update from 15 to 16 external content on projects is not linking anymore. For instance on our title blocks for each project we have pdf's of logos as most companies would. Since the update, when trying to publish the sheets to pdf or dwg 16 doesn't recognize the old file path, and needs to be told again.
This may seem a small flaw. But consider a company which has numerous designs and sheets, and you will get the picture.
The files have not been moved or changed.
Which update? What version and hotfix? What OS platform? Are you running solo or Teamwork?
Are you working exclusively on Mac or Windows or does the project file move back and forth (in which case the links will not work as they are OS dependent)?
Open Drawing Manager and sort the linked content to the top and post a screenshot of some/all of the linked entries.
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
The update was from AC 15 to Ac 16. Running solo. Using windows 7 64 bit.
It only happens during publishing of sheets. I have to open the drawing manager and manually link the pdf logos that are already there and have been working fine before.
