MS-Word Document Problems
I have several MS-Word documents that contain bulleted and/or numbered lists. When I import the documents into PlotMaker, they look fine. However, when I print the layout, PlotMaker discards all of the first level of numbers. It keeps all the numbers/letters from all other levels, but I can't get it to keep the first level. This has happened on two different projects by two different users. Any ideas?
vfrontiers
I have had MANY OLE problems similar to yours... Look great on the screen, but plotting is a different story. Many times it looses FONT info, sometimes it would ENLARGE the text (to 200pt+) or shrink it..
But I have been in the process of converting everything to EXCEL which I have yet to have a problem with! My contention has always been that GS needs to buy one of those rinky dink little spreadsheet programs in BURN it into ArchiCAD... I like spreadsheet over WordProcess to eventually be able to use simple math (like SUM or ADD)....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
