Magnet behaving differently on Layouts
Two projects open, one began by me, one began by a co-worker.
When I switch to my project, the magnet behaves as I always experience it in all windows, including layouts: Hover over an item long enough it turns color ready for selection; hover and hold shift it turns color immediately ready for selection; hover and hold shift then tab to rotate through multiple items if present.
When I switch to his project (even though I've edited and saved as another name) everything works the same EXCEPT ON LAYOUTS: when on a layout hovering makes no change until I hold shift and then hit tab.
I have made sure to apply my profile in both projects (which includes my Prefs, Shortcuts, Tools and Workspace Schemes) to no avail.
Any ideas? Thanks for the help.
1 REPLY 1
Jeff
That sounds like you have the master layout settings toggled to
Display Master Layout : Above Layout. (just above the Drawing Placement section)
Flick it over to Below Layout and it should be all golden from there.
