Make door/window marker scale dependent
We just migrated to ArchiCAD and we're preparing submittal material for the first project that we've entirely done with this program.
I was wondering how can I make all markers of doors and windows scale-dependent, e.g. I want them to show in the building plans (say, scale 1:100. 1:50 etc.), and to remain hidden at smaller scales (1:200 on).
Thanks!
5 REPLIES 5
David Maudlin
Enrico:
You would not make them scale independent, you would use Model View Options to show them when desired. You should create 2 Model View Options, one with the Markers shown, the other with then hidden, then assign the appropriate MVO to the appropriate View.
For more information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "Model View Options" in the search box, the results list will lead to detailed information.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Your advice is for turning the marker on and off in plan view, but eludes to the scaling factor of the marker in question.
Can anyone advise on the scaling of the marker between various drawing scales? Can Archicad do it?
Thanks
Phil
David Maudlin
Phil:
You will need to clarify your intention. The ArchiCAD markers are scale independent: they are set by point size, which means they retain the same output (paper) size regardless of the scale of the drawing. The scale of the view should be set before sizing the markers so the screen view matches the output. You should post some images of what you are trying to achieve.
David
David,
My intention is to have a plan at 1:100 showing door markers at size shown as ref: D34-01 in attached Plan view scale 1_100.jpg and to have a more detailed part plan at scale 1:50 showing marker size shown as ref: D82-24 in attached Plan view scale 1_50.jpg. At scale 1:50 marker D82-24 is the correct size, however at scale 1:100 marker D82-24 becomes too large! I hope this makes sense? I don't understand "The scale of the view should be set before sizing the markers so the screen view matches the output", what am I missing about scales and setting up views?
Regards
Phil
Incidentally, Archicad 12 is being tried......
Hi Phil,
I can't read any of the text on your image, so following your description of the problem is difficult.
I think the problem comes down to just as David M says - the printed size of the marker stays the same regardless of the scale of the drawing. To keep the text readable at 1:100, the door marker appears too large in comparison to the door.
Would you normally display a door marker at 1:100? Surely the marker text would be too small to read? The opening is only 8mm wide at that scale!
If this feature was an important requirement, you could edit the GDL code of the marker to display something simpler at scales of 1:99 and above. Due to the complexity of the code this is perhaps a more complicated job than it would first appear unless you knew what you were doing!
