Manual entry of dimensions
Is it possible to over-ride the automatic entry of dimension details?
There are some occasions when I would like a dimension to be slightly different to that which is automatically generated .
I know that it's making a 'right-wrong' but it's been a useful feature of Cad software I've used in the past & I can't fathom out if it's possible in Archicad.
6 Replies 6
Djordje
Dangeorus practice - be sure to also change the color of the edited dimensions, so you know which ones they are after a while.
In the lower left of the dimension text, there is a hotspot. Right click on it, Dimension text settings ... and the rest is obvious.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
i like the idea of changing the custom dimensions to another color for easy reference. thanks.
Djordje
Thank Alex Schamenek!
He came up with the idea and it is also formalized in a wish, I believe.
Djordje
HP Omen
Thanks for the prompt ( and sensible ) advice.
Jefferson
Djordje -
What a GREAT yet simple tip for those rare times when it's appropriate to change the dimension to "custom" or "artistic liberty". Keeps the score accurate for you.............Thanks!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
David Maudlin
Also, in the latest build of ArchiCAD (2284), the Info Box will display this information. This is a new section that was added to the Info Box called "Dimension Text Tool".
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
