help; special character
Does anybody know how to type/insert a special character in Label? A "diameter symbol" or a "plus-minus" for instance?
Thanks in advance!
3 Replies 3
Djordje
Find character map; Start/Programs/Accesories/SystemTools/Character Map.
You find something like this there: ALT0177 is ±, ALT0248 is ø and so on ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Here is a tip if you don't work well with codes and numbers (like me )
Go to Dimention Tool - Vertical Dimention and place a Dimention for ±0.00. Then select just the text, open it and Copy the plus-minus character. Close the window , type your text and Paste it. For angles use the Angle tool.
Actually this is how I inserted plus-minus here
Thanks Djordje, Kliment!
been searching this for a quite long time
