Mark-up Autotext
Hello Everyone,
I have a problem, question, discussion about Mark-Ups relating BIM process. Mark-ups sometimes should be created and listed for clients and I am seeking a method how to generate this documents quickly.
Mark-up tool is very good however there is not connection btw Layout book. That would be an highly valuable feature to "Tag and Discussion" can be appeared on Sheets as in form of Autotext (or easier method) using IDs for each issues or a Drag and Drop method to the current Sheet. For a Drag and Drop method to be listed as Revision/Mark-up items in Project Navigator as text information about the presented issue.
Or another idea similar than Opening Schedules. Attached viewport pictures (predefined margin) and text infos could be automatically generated.
What do you think?
0 REPLIES 0
