Marker References and External Drawings
Craig Bagley
If I’m reading the AC15 Reference Guide right, I can create a section viewpoint, then switch reference to “the first placed drawing of the selected view”, and place the referenced drawing in a separate .pln file serving as the Layout Book.
However, the marker auto references in the model file won’t fill in with the Layout Book numbers.
After reading a couple posts here, maybe the marker only updates in the Layout Book (which it does successfully). Having discovered this, the wording in the Reference Guide (p. 651) seems a little vague:
“Once the Layout Book that contains the reference drawing is opened alongside the project containing the marker, the marker will fill in the correct drawing data.”
I would have thought the model file marker would fill in automatically with the layout book numbers.
If layouts were kept in the model file, while for some odd reason the placed drawing was in a separate file, looks like it doesn’t work.
Am I missing something?
AC27 USA/Build 5030 16" MBP
0 REPLIES 0
