Masters and page setup
We have several different size masters in our plotmaker template. The size of each master was established using page setup. However when one prints a layout with a different size master it appears that it is necessary to go through page setup once again. For example if I had previously printed to 18x24 sheets and then went to a layout that referenced a master that was 24x36 and printed, plotmaker will piece together the layout using 18x24 sheets. Will using plot setup instead alleviate this issue or do we need to go through page setup or plot setup every time we output a different sheet size. Thanks for any suggestions.
1 REPLY 1
If you want to store multiple page setups you need to use Publisher.
You can still have one Page Setup and a different Plot Setup. Good for half and full size sets.
