2017-08-0306:22 PM - last edited on 2025-02-0711:26 AM by Aruzhan Ilaikova
Measuring a door in a ground plan - hight difference
2017-08-0306:22 PM
hello,
I have on one floor (hight +3,33) a platform (hight 3,96). They are both a part of the same level. Now I have a door on the platform, hight 2,26m. When I drew a measuring line next to it, it calculated the hight of the entire room, resulting in a door-hight of 2,895 (door hight+platform hight = 2,26 + 0,635 = 2,895).
Is there a way of chaining this, without having to edit manually the value on the measuring line ?
Is the size of the Door Opening larger than the actual Door itself?
Which AC version? Linear Dimensioning options have been added in the last few releases so the answer may depend on your version.
Could you show me a 3D of the Door as well?
And also a screenshot, with the placed Dimension selected, showing the Dimension Details panel of the Dimension Settings Dialog?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
