Minimal user right to publish to PDF on PC
I've installed Amyuni PDF Driver and it works properly when one tries to *print* to "Amyuni PDF Converter", so I guess the setup is correct.
Now I try to publish from Plotmaker to a PDF file, but in the file format dialog, the "PDF File" option isn't avalaible, as if PDF Converter wasn't installed.
As I've seen that PM create a temporary printer based on Amyuni PDF converter to "publish" to PDF, I'd like to know which user rights are needed for PM to be able to create this printer. I currently have very restricted user rights, and for exemple can't add a local printer in Win2000.
Can anyone tell me which right I should ask to the sysadmin for the processus to occur correctly ?
0 Replies 0
