Missing Fonts when Publishing to PDF
I've been trying to publish a drawing set containing several fairly standard fonts (Arial, Trebuchet)...When i publish through the Amyuni driver via the "temporary Archicad 10 publisher" printer, any Arial font text is missing. The fonts do show up in the published pdfs when i switch the temp printer driver from amyuni to adobe pdf...but that driver is much slower. Is this a problem with the amyuni driver, or am i missing something?
- Scott
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
12 Replies 12
SuperJasE wrote:
What you can do as a temporary workaround is use the free 30-day trial of Acrobat 3D. There doesn't seem to be a free trial of the more reasonably priced Acrobat Pro 8.0
I would gladly use that. Problem is that if you try to print (to Acrobat or Amyuni, you apparently can't print all the sheets in one file. And if you "save" to PDF it uses the Amyuni printer automatically (from my observations). So I'm caught between a rock and a hard place.
Djordje
Yes you can.
The trick is to have a top folder that contains all the layouts you want to publish. Click on that folder, set the parameters (paper size etc). In the bottom is the checkbox for publishing everything to one multi page file.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Check - have that
Check - have that too
Nope, can't find the button. THAT's the problem right there. See attached pic.
