2023-01-03
07:48 PM
2023-05-09
05:47 PM
Gordana Radonic
Hello all,
I have a question regarding missing fonts in Archicad 25. My company uses a common font for all of our projects. My computer had the font missing, so I had to download it. I can see the font in Archicad but wanted to know if there is a way I can replace all the text using the missing font with the new downloaded one.
Currently all the text items using the missing font shows in [missing font], and has been replaced by a standard one. If anyone can tell me how I can adjust those setting, it would be helpful. I am trying to select a default font that Archicad would use to replace any missing fonts currently in the project and in the future.
2023-01-07 01:25 PM - edited 2023-08-30 03:01 AM
The text should know what font it was and show the font name in brackets - i.e. [Helvetica].
As soon as you install Helvetica (or the missing font) into your operating system, all should be good.
You will probably have to close Archicad and re-open it.
But the font should automatically be there once you have installed it properly.
If you are actually seeing [Missing Font], I have not come across this and I assume you will have to manually fix each instance where this occurs.
