Model View Option Combinations
Is there a way to save a model view option combination group and then export it, in lieu of exporting each model view option individually? Is it possible to have the same set of model view options come up every time I save a drawing as a view?
Not sure about the first question. All of our Model View Option Combinations are setup in the template file.
Your model view options are set when you create or redefine a view.
Link
You'll need to set up a publishing set specifically for export.
This set will access views that contain all the settings (inc. model view option combinations) specific to export.
Link.
