discord between drawing and printing scale; help please.
I created a master layout to C Ansi engineering (22"x17") to fit my canon printer. My floor plans are drawn to 1/8" which, when I print direct from ArchiCad, show that they should fit exactly onto that size sheet (with 1/4" border). They register as 1/8" scale when I check the drawing settings in plotmaker (input and output), but in the plotmaker window they show much more space all around them and when I print in plotmaker they print on 4 sheets and have lots of room all round them. I can't understand why the imported drawing does not almost fill my layout sheet. Please tell me what I am doing wrong.
ArchiCad 8.1. pm 3.1
4 Replies 4
TomWaltz
I could be wrong, but it sounds like your margins are set too big on the master layout.
Tom Waltz
Djordje
Set your Master layout to read the margins fromt he printer. I don't have 8.1 installed now, will have to check and remind myself ... it was four years ago ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thank you Tom and Djordje. I had already set my margins to the printer, but you made me think about the size of my layout and then I discovered the really stupid thing that I had done - I calculated Tabloid paper as 22"x17" instead of 17"x11". Whatever you do don't grow old - you start losing your marbles at 70!
Djordje
Good that you found it ...
... and don't worry, I have quite a few already lost at 46 ...
Djordje
HP Omen
