Model based construction progress tracking
hi all,
we are looking for a way to get a workflow to get the status of construction progress per element (e.g. wall; concrete done, insulation done, plaster done, paint done,...) into the model to visualise progress in the model.
Anyone can point us in the direction how that can be done with a Archicad model?
Thanks!
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
i think the easiest way to do it is to combine the Construction Simulation feature in ARCHICAD with Property attribute
you can create custom properties such as:
start date
duration
end date
construction status
use formula to determine the status, something like: "if current date <= end date = "DONE"
extract those properties on a schedule
Thanks for the hint - but how can I, standing in the construction site with my tablet/ phone, how can I edit these attributes?
Ahmed_K
Mentor
I'm trying to find a solution for this too,
So far, the best way is to use excel on a tablet and check items manually ,
OR
use an IFC viewer that can edit ifc properties , select item in the model, change it's statut, and send back to Archicad,
Did you find a better workflow ?
Archicad 27
Windows 11 professional
