Myles
plan and section view
Hi all,
I've made a complex profile and it works fine in plan view .... then I move it in section  place it, and I can't see it again in plan view ?
Any thoughts all  ??...
weekend is almost here !!
regards Myles.
3 Replies 3
Andrii Levko
Maybe you have "Cut only" selected in Dialog Settings >> Floor Plan and Section >> Floor Plan Display.  Try to select "Project with Overhead".
Andrii
AC 8.1 - 28 INT/POL 3001
Win11
Hi there
The below might help, it's a little troubleshooting list I get the guys here to go through when something isn't showing.
  1. Check layers.
  2. Check renovation status.
  3. Check what story the element is on.
  4. Check what stories the element is set to show on (E.g. home story only).
  5. Is the trace reference on? (E.g. Trace reference has option to hide fills).
  6. Does switching to another “Model View Option” work.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
David Shorter
@Myles.Not clear did you place the profile IN the section view or just move it there?
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
