We value your input!
plan and section view
Myles
Hi all,
I've made a complex profile and it works fine in plan view .... then I move it in section  place it, and I can't see it again in plan view ?
Any thoughts all  ??...
weekend is almost here !!
regards Myles.
Andrii Levko
Maybe you have "Cut only" selected in Dialog Settings >> Floor Plan and Section >> Floor Plan Display.  Try to select "Project with Overhead".
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
Josh Verran
Hi there
The below might help, it's a little troubleshooting list I get the guys here to go through when something isn't showing.
  1. Check layers.
  2. Check renovation status.
  3. Check what story the element is on.
  4. Check what stories the element is set to show on (E.g. home story only).
  5. Is the trace reference on? (E.g. Trace reference has option to hide fills).
  6. Does switching to another “Model View Option” work.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
David Shorter
@Myles.Not clear did you place the profile IN the section view or just move it there?
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
