2020-03-10
04:05 PM
2023-05-30
12:22 PM
Rubia Torres
Solved! Go to Solution.
2020-03-11 02:49 PM
2020-03-10 04:49 PM
2020-03-10 05:21 PM
2020-03-11 12:19 PM
2020-03-11 02:23 PM
DGSketcher wrote:Thanks for your answer!
Try "New 3D document from floor plan" more info here: https://helpcenter.graphisoft.com/user-guide/76809/
This way you can produce as many plans as you like without worrying about element display orders as they will be displayed as if you had just sliced the top off your model. You can do a lot to control the display style so it might take a little bit of effort to set up your initial drawing.
2020-03-11 02:36 PM
Braza wrote:Thanks for your answer!
You can always duplicate the Plan View Map and change the Floor Plan Cut Plane (AKA FPCP).
You can find information here.
Hope that helps.
p.s.: Ah! And you can place a linked section marker inside your section and link it to the plan View Map.
2020-03-11 02:49 PM
2020-03-11 05:00 PM
matleonii wrote:
I noticed that the FPCP seems like a global setting. So when I change it it affect the other copys os the plan views.
Not really. You have to set individual FPCP to each View Map. Like this.
2020-03-12 02:30 AM
Braza wrote:
DGSketcher solution is another option. But I tend to avoid 3d documents for performance issues.
2020-03-12 11:32 AM
