No Shadows in 3D View - Hardware Acceleration
reidweber
Hello, I recently upgraded to Archicad 26. Originally, I accidently downloaded the INT version of Archicad instead of the USA and was working in that file for about a week. I then realized the error and downloaded the USA version and opened the file.  I'm now finding that none of the 3D views are casting shadows while in the Accelerated Engine.  I've looked at the obvious spots like checking "shadows" are on under 3D styles, the sun angles, and sun options. Are there any other places to check that may have shadows turned off? See the before and after below and my settings screenshotted.
Thanks,
Reid
Screenshot 2023-01-10 125902.pngScreenshot 2023-01-10 130050.pngScreenshot 2023-01-10 130112.png
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
reidweber
I opened it up today and the shadows have returned. Should have started with the ol' restart method first. Thanks.
4 REPLIES 4
ryejuan
have your tried checking on your GPU?
WINDOWS 11 PRO
reidweber
Wessler Camila
Same here! I closed the model and opened and it worked, the shadows showed up again.
Cleon
How strange. I found the same issue, jumped on here and tried closing and re-starting. Walla resolved!
